So many detailing products........
by buster
05/04/16 10:00 AM
Why is Mobil Delvac 1 so expensive?
by pb379
05/04/16 10:00 AM
2017 F-150 3.5 twin turbo V6
by OneEyeJack
05/04/16 09:45 AM
Fort McMurray Fire 80,000 evacuated
by Smokescreen
05/04/16 09:40 AM
Apparent dilution ratio discrepancy????
by Sayjac
05/04/16 09:31 AM
Ceramic brake pads
by bigdom
05/04/16 09:24 AM
how to verify oil in a manual transmission
by yvon_la
05/04/16 09:21 AM
14 F-350 Rotella T-6
by Erreich
05/04/16 08:43 AM
Why Measure Trans. Fluid with Engine Running?
by doitmyself
05/04/16 07:39 AM
Is Pennzoil discontinuing High Mileage 10W40?
by aquariuscsm
05/04/16 06:55 AM
Lowering vehicle with alternative coil springs
by OlDirty
05/04/16 06:22 AM
Remington R1 1911 or Springfield 1911-A1 MIL-SPEC
by MuzzleFlash40
05/04/16 06:02 AM
Palmer, jessanmark16, danbee, PTT, greasy_knuckles5
57790 Registered Users
77 registered (bdcardinal, badtlc, AUTOTECH89, Al, Astro14, Bandito440, 6 invisible), 1740 Guests and 284 Spiders online.
57790 Members
66 Forums
248451 Topics
Page 1 of 2 1 2 >
#1655432 - 11/02/09 12:39 PM Antigel Temperature
Oldwolf Offline
Loc: Cary, NC
At what outdoor temperature should I use antigel in my diesel fuel?
2005 Prius: Mobil 1 Blend (50%)0W20+(50%)0W40
2012 Prius C: Toyota 0W20
#1656863 - 11/03/09 02:54 PM Re: Antigel Temperature [Re: Oldwolf]
Dieseldoctor Offline
Loc: tn usa
Depends if it's summer or winter most blend fuel to the conditions changes i think 40 degrees for untreated. I've always only done it if temps drop below 10 degrees i'm not far far your location hope that helps.
#1665578 - 11/10/09 09:39 AM Re: Antigel Temperature [Re: Dieseldoctor]
Oldwolf Offline
Loc: Cary, NC
Hey. I am wondering at what temperatures should I start to add anti gel to my fuel here in North Carolina. The only concrete answer I have found so far is this:
Quote:
Diesel petroleum fuel will start to gel up around 10F. It starts to cloud at 32 degrees, which means it is starting to gel.
So cloudy diesel is OK? It won't gum up the works?
#1665584 - 11/10/09 09:44 AM Re: Antigel Temperature [Re: Oldwolf]
Oldwolf Offline
Loc: Cary, NC
Another good read:
Quote:
POUR AND CLOUD POINT: Pour and cloud point should be tailored for your specific climate needs. The cloud point refers to the fuel's temperature as it begins to thicken and "cloud." The pour point refers to the temperature of the diesel fuel as it thickens and will no longer pour. Some engines will fail to run at the cloud point, but all engines will fail at the pour point. Usually the cloud and pour point are 20 degrees apart. Normal cloud point often occurs at 40 F and pour point at 15-20 F with DF2 fuel. If you are in a cold climate, use winterized fuel or winter blended diesel fuel, which is a mixture of DF1 and DF2. DF1 has a lower pour point, but also has a lower viscosity, or weight, and is harder on the fuel injectors, which is why blended mixture is recommended for cooler climates.
http://www.itow.org/fuelguide.htm
#1676955 - 11/18/09 10:45 PM Re: Antigel Temperature [Re: Oldwolf]
m37charlie Offline
Loc: Alaska
It totally varies according to what is been sold at the pumps. In Alaska fuel is sometimes sold that stays usable down to -47 to -50 C.! Living in Anchorage I have never had a problem (except once, when I went to a low volume station owned by some unscrupulous people from another certain country) at temps down to -30 F. (-35 C.)
On the other hand I did have a stoppage at Christmas 1975 running Mexican diesel at ~+10 F.
Diesel fuel comes in many mixes and specifications with cloud points ranging from +40 F. to -58 F. (Jet A50).
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#1682916 - 11/24/09 09:23 AM Re: Antigel Temperature [Re: m37charlie]
salesrep Offline
Loc: lllinois
To answer your question. Today.
Get one with a moisture dispersant and some detergents as well.
It is just good practice in the Fall to try to eliminate excess moisture from today's fuel before winter to prevent filter freezing and get some anti-gel rolling should you catch a poor batch of fuel.
"A patriot must always be ready to defend his country against his government."
Edward Abbey
#1683019 - 11/24/09 10:57 AM Re: Antigel Temperature [Re: salesrep]
Oldwolf Offline
Loc: Cary, NC
But...when the temperature hits 32F, the cloud point, I should add AntiGel...I think.
#1686062 - 11/26/09 11:56 PM Re: Antigel Temperature [Re: Oldwolf]
m37charlie Offline
Loc: Alaska
It still depends. If you are in New England or Montana or Alaska or Canada and it hits +32F., no worries. In Mexico, big worries. Because of the qualities of the fuel being delivered.
In China they sell vehicle diesel fuels with cloud points from +5C. down to -30C.
You haven't said what vehicle you have.
If you have a heated filter/separator, it adds ~15 deg.F to the fuel.
Charlie
#2091857 - 12/01/10 08:19 AM Re: Antigel Temperature [Re: salesrep]
Oldwolf Offline
Loc: Cary, NC
What do you consider to be a good additive?
Currently I use 6 oz Diesel Kleen and 6 oz TCW3 two stroke oil per 18 gal fill up.
Is this an overkill, is there a better additive to use?
#2092216 - 12/01/10 02:48 PM Re: Antigel Temperature [Re: Oldwolf]
salesrep Offline
Loc: lllinois
The 6 oz. of 2 stroke is likely a little on the high side.
I think a guy should use a treatment specifically designed to go into the fuel system.
Schaeffers Diesel Treat 2000 Premium Fuel treatments are top of the line. Of course there are others.
Edward Abbey
#2092913 - 12/02/10 08:25 AM Re: Antigel Temperature [Re: salesrep]
Oldwolf Offline
Loc: Cary, NC
Where do you buy Schaeffer products?
#2092957 - 12/02/10 09:02 AM Re: Antigel Temperature [Re: Oldwolf]
salesrep Offline
Loc: lllinois
You can go to Schaeffer oil's website and search for a retailer near you. Larger users can ...
Edward Abbey
#2093082 - 12/02/10 11:06 AM Re: Antigel Temperature [Re: Oldwolf]
Oldwolf Offline
Loc: Cary, NC
Nearest one is 87 miles away!
#2093406 - 12/02/10 03:51 PM Re: Antigel Temperature [Re: Oldwolf]
BobFout Offline
Loc: Indiana
Oldwolf,
I agree with Salesrep, the time to start using winter additives is in the fall, before it starts getting cold.
Any of the name-brand winter formula additives should do you well:
  • Power Service (white bottle)
  • Stanadyne (all-season)
  • Amsoil (cold flow improver and cetane boost)
  • Schaeffer (winter version of DT2000)
  • Redline (winter version)
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
#2111166 - 12/19/10 08:13 PM Re: Antigel Temperature [Re: BobFout]
BobFout Offline
Loc: Indiana
Originally Posted By: BobFout
Oldwolf,
Hm, I left off Howes Diesel Treat off the list.
Page 1 of 2 1 2 >
