Butcher factory cooler lines?
by buck91
23 minutes 35 seconds ago
Grease for marine davit crane
by davebe
Today at 09:10 PM
2016 Traverse, which oil would you use?
by chevman4life
Today at 09:08 PM
acclimating to heat - tips, please
by pandus13
Today at 08:53 PM
95 Ford Ranger - Runs rough, no power
by dsmith41
Today at 08:49 PM
False teeth
by Eddie
Today at 08:49 PM
Quaker State engine warranty...thoughts?
by ryan2022
Today at 08:46 PM
Hicks Oil
by yankees1
Today at 08:32 PM
Looking For A Good Battery For 2011 Santa Fe 3.5V6
by crazyoildude
Today at 08:18 PM
Pre-detonation
by edhackett
Today at 07:43 PM
SETI Investigating Signal
by buster
Today at 07:42 PM
Ontario: Energy has never been cheaper...
by OVERKILL
Today at 07:36 PM
davebe, Logos, alphanumeric, koidragon1980, iliveonnitro
58961 Registered Users
100 registered (4WD, 69GTX, akela, ammolab, 2009Edge, 9 invisible), 1517 Guests and 9 Spiders online.
58961 Members
66 Forums
253756 Topics
Page 2 of 2 < 1 2
#2122734 - 12/31/10 01:12 PM Re: Antigel Temperature [Re: Oldwolf]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Keep a bottle of Diesel 911 around as well, good stuff for drying out watery fuel. If your '93 is like my '82 300D, there is no heater on the fuel filter. I also try to keep all diesel tanks as full as possible, especially in winter, to cut down on condensation. Mac's Antigel is also available at NAPA, I have a gallon in the basement that I got on sale, fortunately haven't had to use it!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#2122738 - 12/31/10 01:18 PM Re: Antigel Temperature [Re: Oldwolf]
Points Offline
Loc: MN
I had a VW jetta TDI for many years and I used a qt of e85 gas when the temps are below -10 here in mn.
#2123175 - 12/31/10 08:08 PM Re: Antigel Temperature [Re: Points]
BobFout Offline
Loc: Indiana
Gas in a TDI (or any modern diesel)? crzy
Gas in old diesels can be OK per the manual, but never in a modern diesel.
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
#2127979 - 01/05/11 08:25 AM Re: Antigel Temperature [Re: bullwinkle]
Oldwolf Offline
Loc: Cary, NC
I do have a fuel heater on my engine that is thermostatically controlled. At any rate, I am now adding 6 oz. of Diesel Kleen Anti Gel at every fill up. The winter here has been pretty mild so far though.
I usually fill up at about a quarter tank. I hear you about keeping the tank "fuller" to minimize condensation.
2005 Prius: Mobil 1 Blend (50%)0W20+(50%)0W40
2012 Prius C: Toyota 0W20
#2128057 - 01/05/11 09:44 AM Re: Antigel Temperature [Re: Oldwolf]
scurvy Offline
Loc: Chicago IL USA
Originally Posted By: Oldwolf
At what outdoor temperature should I use antigel in my diesel fuel?
That greatly depends on the quality of fuel you buy.
I keep a mason jar of untreated-by-me fuel from my local supplier of B11 in my unheated, uninsulated garage. It has remained bright, clear & completely liquid even at -28C [-17F]. I still tend to dose my fuel with Howes Diesel Treat or PS White once temps start straying down to -15C [low single digits F]. Never had a gelling problem or iced up fuel filter.
Especially with modern diesels, buying the highest quality fuel you can find is one key to long-term value.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#2355664 - 08/23/11 07:51 PM Re: Antigel Temperature [Re: Oldwolf]
2cool Offline
Loc: Delaware
I use Howe's Diesel Treat. I can get it in all of the chain auto stores or any travel plaza serving trucks. I also use it in my heating oil, and my heating tech comments on how clean the system is at each annual service.
#2785163 - 10/27/12 08:53 AM Re: Antigel Temperature [Re: Oldwolf]
TiredTrucker Offline
Loc: Central Iowa
Gelling is only one problem. Icing is another. You need to have an additive that tackles both. There is almost always traces of water in diesel. Usually not a problem. But when it is, it is a big one. I go thru around 21,000 gallons of diesel a year, so I can't afford to run into problems. But I am prepared. Over the years, I have grown fond of the Amsoil line of diesel fuel additives. Their Cold Flow Improver is pretty good. Recently, the son of a friend approached me about XLP Diesel Fuel additive. I dug around looking at specs for it online, and it is pretty close to the Amsoil stuff. It is made by an outfit in Olathe, KS under contract from Chevron for, if you can believe this, Amway! Price at application rate seems reasonable... 2/3 the cost of Amsoil line. I am going to be a guinea pig and test this stuff all this winter.
Since having my semi truck operational with low problems is critical in winter, I start putting additive in when we approach 32F. I get fuel from a variety of locations around the upper midwest, and even the top name outlets have occasionally had a load of fuel that didn't hold up well in cold temps. I don't play games and take chances. A gel up or other problem 700 miles from the house is not a good thing. I always carry spare fuel filters and additives.
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
Page 2 of 2 < 1 2
