"1. Trasko in Brief: The Trasko Refining Unit came about when the Govt. officials of the Tokyo metropolis started exploring the possibilities of improving the maintenance of their vehicles for increasing their longevity and reducing environmental impacts. In 1985 the Trasko-Bee Corporation in a joint venture with the Subaru Motor Corporation in Japan introduced this refining unit and won an award from the Mayor of Tokyo. The manufacturing premises were expanded to establish The Trasko-Korea Co. Ltd. August 1998, rehman enterprises introduces the Trasko Ultra-Fine Unit for the first time and makes it available both for fleet and individual use."
I have one that I cannot use on my car due to size. I originally bought it for my Dodge Dakota. It works nice. It is well made and it is reusable the casing is. It use's a special element that looks like a tube of TP but it is not. It is wound many times tighter then TP and is single ply. It is oven backed in a kiln and will not channel the way TP does. The center tube is also thicker then TP. Never use TP in them even if it will fit! TP is not wound tight enough and will channel which makes the bypass feature worthless. The filters that are designed to use TP pre tension the TP and require more freq. changes. The Trasko the first time you use should be changed at 6 months but after the first use if you keep using it you can go 1 year between filter element changes unless they have changed things.
So after I go rid of my Dodge my Dad used the remaining three elements I had along with the filter on his Tacoma. It has been sitting in my pole barn now for a while! I need to get a remote filter relocation set up for it.
If I had the money to spend I would get one for my power steering and for both of my Mom's automatics!
I am going to be useing mine when I go to 12 month oil change intervals!
Originally Posted By: fonebone
Wait, there are filters like this that ARE designed to use TP???
It uses a roll of paper like a TP roll but obviously not exactly. It does not filter by forcing oil through all those layers (from the center to the outside like normal oil filter). It filter by forcing oil from one end to the other.
