Originally Posted By: Gary Allan
Originally Posted By: webfors
xlm is a great groupIII syn, like PP. Use it with confidence. I run PP5w30 year round, and I live further north eh!
Ummm. No.
Ottawa's center is 45 degrees, 25 minutes, and 15 seconds north latitude.
North Dakota's southern border is 45 degrees and 56 minutes north latitude.
So basically, Ottawa is about 37 miles (~60km) south of North Dakota's southern border.
Chances are the OP isn't lving right on the border, so he's probably farther north of Ottawa than that.
hah, I guess I need to look at a map more often! Buy hey, how far north can he drive before he hits the end of the line without pulling out a passport
If you were quick you may have said something like, "That's only of you're using geography as your "border". Look at jetstream contours instead."
..now for all I know it makes your position even worse, but it throws a curve in the conversation to allow you a temporary escape hatch.
Looks like ND is closer to the prairies, and they get the worst of it up here. So I'm not sure if that would of stood the test...
