PT1, If you check Harley's web site it still recommends using their syn 3 in the trans. I don't use it but if I suddenly found I needed oil, I'd use it. I've been running Amsoil 20/50 in my '03 ultra for a few years and it works perfect. It's a gl1 rated oil and thats really all a Harley trans needs. I would be a little skeptical using an oil that is too heavy in the trans. A Harleys trans isn't subject to high heat,or high horsepower. And when it gets cold may not flow as well as needed to lubricate bearings. If your using heavy oil to mask a whine your not fixing anything, just covering it up.,
