I have a '98 Ranger with the 3.0 Vulcan. Top of the cap calls for 5w30. Later model Rangers call for 5w20 oil. I've tried to do some research on how far the 3.0 in Rangers were back spec'd to 5w20 and the consensus I found was '99. I kinda wondered why, but didn't really find any answers.
I read this relatively new article here:
http://www.therangerstation.com/tech_library/3_0-build.html
It basically says that in '99, they made the head bolts just a bit longer resulting in reduced bore distortion and better sealing rings which then resulted in reduced oil consumption and contamination.
So with that in mind, in my '98, would I conclude that if I ran 5w20 in it, I would see more contamination/consumption than I would if I ran 5w30?
