I have a 2004 International with a VT365 motor. The truck has about 108,000 miles on it. The truck overheated while we were driving it on the interstate and blew some of the coolant out through the coolant resovoir cap. Upon closer inspection the coolant resovoir had a 16 psi cap on it instead of the stock 10 psi cap. We replaced the cap and the coolant resovoir (cracked) and it blows coolant out as it is being driven due to pressure in the coolant system.
I'm not sure if this is due to a bad head gasket or EGR cooler. Any ideas?
