KenO
Thread starter
Originally Posted By: 4wheels
If you like Redline, then the D4 ATF is actually the correct fluid for this trans (just as Redline suggested). It's the same viscosity range (within tolerance anyway) as the factory fill. I've heard of some folks running MTL, but it'll be a bit harder to shift. Some have had issue with the Redline needing more frequent changes than the OEM BMW fluid.
You could run the OEM BMW fluid. It's good stuff. The BMW stuff can be mail ordered for about $30 per liter from online discount BMW parts stores, or you can try an OE alternative made by Pentosin who does supply some BMW factory fluids) for ~$20 per liter.
For 3x the price of Redline, no thanx on the factory fill. Even if I have to change it every 15k I'm money ahead.
