Quote:
There is an interesting article by Mike Kojima on another site (can't post the address here) that goes
into great detail about the Nissan oil. The price is about the same as Redline. Here are a couple of quotes:
"Nissan's special oil and their newly developed hydrogen free DLC coating on cam followers reduces the amount of friction produced by the valve train by a huge amount. This can make a considerable difference in fuel economy, power output and perhaps even heat generation.
What is Nissan's special oil? The oil was developed to complement Nissan's Hydrogen free DLC coating used on the cam followers in the QR25DE engine, the VQ35HR and the VQ37VHR engines. DLC stands for diamond like coating, which is an amorphous layer of carbon crystals with hard smooth properties much like diamond. Most of valve train friction is created by the interface between the cam follower and the cam lobe. DLC is very slippery stuff and Nissan uses it to reduce valvetrain friction to improve fuel economy, reduce emission and increase power.
Nissan, in their search for improving oils frictional properties, figured out a way to substitute ultra hard nano particles for the normal chemical friction modifiers adding some interesting molecular twists. Again due to the convoluted nature of Nissan’s white papers and patents, its hard to guess exactly what the nano particles are but they are definitely an ultra hard industrial abrasive or bearing type ceramic and probably at least in part, nano particles of industrial diamond
Nissans super oil is around 0.5% nano particles by weight. The particles are probably around 10 nanometers in diameter, really very small! A certain percentage of the nano particles have to be carbon based, preferably single crystal synthetic diamond. The carbon content helps make the nano particles attracted to the low hydrogen DLC coating. Instead of making a slippery metallic film on bare metal parts like traditional friction modifiers, the nano particles act like atomic level miniature ball bearings, preventing metal to metal contact and reducing friction to previously unheard of levels. These nano particles are ashless if they find there way into the engine, making the oil low deposit forming for lower emissions. The Nissan super oil does most of its friction reduction in the valvetrain but it still helps in other parts of the engine, particularly in areas where metal to metal
370z
