Originally Posted By: Soobs
Originally Posted By: Bottom_Feeder
I've only been using something else (Champs) recently just out of the desire to try something else.
I've got an STP Oil Filter S2869 that came free at a Autozone oil deal for my old '95 2.2L Legacy that I'm planning on using when it's time for another oil change. Just out of curiousity do you know how high the bypass relief valve is set on these? There is no anti-drainback valve, but it seems like nobody uses ADBV for the older 2.2 and 2.0 Subaru engines. This car has over 413,000 miles on it and it's seen a mix of aftermarket and oil-change shop filters it's entire life and nothing but good ole fashion dino oils. I used a "FRAM High Mileage" oil filter on it once and it ran like garbage. I don't think FRAM is even making this filter anymore as it was just a gimmick and was a very poor design. Since that experience I decided to do that last few oil changes with OEM oil filters.
Nope, I do not, but the STP is a Subaru-specific filter made by Champion Labs so I am giving them the benefit of the doubt that the pressure relief rating is correct.
Purolator specifically states the correct bypass valve specs, has the correct mounting thread depth, and does not use an anti-drainback valve, so I have no issue using a Purolator or Purolator-made filter (ProLine, Group7, Motorcraft, newer Bosch, newer MANN, etc.) that has the right application number.
Fram does not make a Subaru-specific filter (for my application at least- it's a Honda-style filter) and neither does Wix (same problem) so I don't and won't use either, but Champ does. Honda-style filters have a lower bypass spec, deeper mounting threads, and an anti-drainback valve. They are not made for Subarus, they only just happen to fit on them. Champ filters have the right thread depth and lack the unnecessary anti-drainback valve, so I'm only assuming that the bypass valve is also correct. I should probably try to email someone there and ask just to be sure, but I'm not really that worried about it.
I'm using that exact STP filter on my car now and have another one in a box, along with two Champ-branded filters and an ACDelco that are all basically the same filter. Use it and don't worry about it. It's a fine filter.
Just keep in mind that my car uses the older, larger filters that Subaru does not seem to use anymore. They went smaller for clearance reasons and some companies spec this new smaller filter even for older applications. I have no idea what the bypass valve specs are supposed to be but I assume it's as high as the older, larger ones. I'm still not going to use a smaller filter when the larger 'correct' ones are readily available.
