I had never given a whole lot of thought to oil in my ATV's. I'd always just used 10w30 or 10w40 conventional auto oil, usually pennzoil or castrol gtx. About a month ago I decided to go with synthetic oil. I had used Mobil 1 5w30 in my Explorer for 10 years and had been very pleased with the results. A trip to the cycle assesory shop and a look at their $10-$14 per qt syn. cycle/atv oil was a no go. I started researching and learning info about oil and I learned alot (never knew about oil groups or all the ingrediants in additive packages). Armed with some knowledge I started to find out what other people used in atv's. Rotella syn. 5w40 was very popular. I went and picked up enough to do all 3 of my machines (all air cooled 300-450cc's)all are doing great with this oil. As I continued to read and learn it dawned on me most of the praise this oil was getting was from posts '07 and earlier when the oil was CI-4. The new CJ-4 has much less ZDDP. Delvac 1 syn has more ZDDP but when I finally located it it was 31.95 gal vs the $19 I paid for Rotella. It's also supposed to be all or mostly PAO true syn. instead of group 3. I've been mulling over the choice, then yestreday at Walmart I fould gallon jugs of Mobil 1 TDT for $21 it's not exactly the same as Delvac but is very close. What do you guys think? didn't find and UOA's on TDT , would you use info on Delvac 1 as a replacement for TDT when comparing to Rotella, comparing CJ-4 TO CJ-4. Thanks for any advice you can give.
