Originally Posted By: Corvette Owner
1) There is a falling hazard if it doesn't have a removable "fence/chain" and it is ALWAYS replaced. A strong metal cover would be an option, but would be hard to lift/move.
Yeah, I was thinking a plywood/2x6 lid, with removeable poles in each corner of the cinder blocks for chains.
2) There is a minor breathing hazard, carbon monoxide could buid up and cause a problem. Someone mentioned a ventilation system.
I have a couple 20" industrial fans that I could probably point down the hole to keep it ventilated quite well, without actually having to run any wiring INTO the hole.
3) You need to be careful when driving over it (side rails would be good).
Yeah, I was thinking about building some metal rails that could be moved apart for different wheel widths.
5) Lighting is needed, as it would be dark in there (as someone already mentioned).
Probably would just use a normal portable work light. I think you can get explosion proof models pretty cheap. Or maybe just a good rechargeable LED light?
Originally Posted By: bustednutz
Nothing like being trapped in a pit with a burning car above it.
Not a wise idea.
Don't mean to be rude, but I wouldn't be stupid enough to trap myself in there in the first place. The pit would be longer than the vehicle, probably with a ladder at one or both ends. And a fire extinguisher. I figure if Jiffy Lube employees can be trusted to run an oil pit, I should be able to do it safely. Unhooking the vehicle battery first would be a must.
As for cost I might be able to get the hole dug for free, and I'd do the brick work, so it wouldn't cost much more than the cinder blocks. Though, I haven't calculated how many I might need yet...cast concrete might be cheaper.
Additionally, it might make a handy-dandy storage area when I'm not changing oil.
