Same here on my 01. Super easy fix that appears to have a much more significant issue that it's not. Have'nt had a problems since I replaced the VC gasket. (years)
Originally Posted By: MNgopher
Originally Posted By: 440Magnum
Are you double-dog certain its not the valve cover gasket leaking and running down so it drips off the bellhousing? Pretty common occurrence and an easy fix.
That's what it was on my Cherokee - not a rear main seal. Check the valve cover gasket, particularly at the back of the engine
