.0007-.0016 Crank Oil Clearance
.0008-.0017 For Piston to Bore oil clearance
.8662-.8665 Wrist Pin oil clearance
This is engine has more small little pieces to keep track of then past Toyota's. Their are two different pistons used one made by TMC and another by TMMK they look identical in the draw's except for the markings on top of the pistons but they ahve the same specifications.The shop manual does not give a year for the piston squiters as in when they showed up. It also does not give oil pump output and bypass number's! If I still had AllData access I coudl look it up!
For Comparison I have my 1970-1987 Service Manual for Carolla's/Carina/Terrcel and Starlet all Toyota's they had 14 different engine combo's but the specifications are all simalar.
All have main bearing clearances from .0005-.0016 for gasoline engines which is right in line with the uber modern 2AZ-FE.
Piston to bore oil clearance .0010-.0020 again it is in the range of the new engine.
My point is that the more things change the more they stay the same. The clearances which will determine what oils will work in it and what is best practice are determined a lot by clearance although today it is more about CAFE!LOL You do not want to know what oils where recommender for these engines because while their clearances of key parts is still in line with todays most modern engines the oil recommended is not!!!LOL
So anyone that thinks clearance are oh so much tighter today that is probably only true if you drive something made in Detroit, Canada or Mexico the rest of the world has not changed much since the 1970's. Materials have changed,designs have changed, surface finishes have changed and so have oils but not so much clearances!
So anyone that want's to rant about tighter clearances and 5W20 and flow issues etc....better be able to back their junk up with clearance changes. If clearances are the same as 1970 then the SAE Oil Charts that used to come with cars are just as relavent today as then. Obviously one has to look at improvments in base stock of 5W30's and such but the additive pacakges are weaker then the 1970's with reguard to ZDDP and not much has gone into the bottle to replace it that I have seen!
So with the above said who is lieing to whom????? This is not a thick verus thin rant or debate either. It goes to what is truth and what is convient recomendation for OEM? Before we could think for our selfs now we cant? This goes to who is doing the thinking the owner or the seller?
Clearance are science and factual recomendation in an owner manual are just that recommendations and paper will not refuse ink now will it!
I hate it when things are dumbed down like that is what we need more of in America more dumbing down! So question things from time to time.
My 2AZ-FE numbers came from an Offical Toyota Service Manaul my second set of numbers comes from a Chilton Manaul but it has to date been accurate. I do have a Offical Toyota Tacoma Service Manaul around the house some place as well.
