Originally Posted By: river_rat
Originally Posted By: daman
yea looks like it, there pretty good built filters,just test it up Rob then compare to the others,keep records of your work.
FYI, It has to be tested simultaneously with others since this is a side by side exam.
The oil talc mixture changes slightly in composition as each dipping retains some oil and talc in the filters. When I remix or add to the oil/talc, the comp changes a little again, so I need to run new elements at the same time, then clean all of them the same, then run them again at the same time, etc.
I try to keep all the variables the same so that when a pile of dirt keeps coming up higher or lower in one brand, I feel like I know what's going on.
I'll pick up a new P1 (the cheapest gold-standard), maybe a new standard Delco.
Rob
thats cool rob,whatever you need to do!!!
