Originally Posted By: 92saturnsl2
It is open loop operation that concerns me, because the ECU will pick the AFR off the map designed for gasoline at WOT. This might create a lean condition in the worst of scenarios (wide open throttle). Is my thinking flawed?
It makes sense, but I think the computer still uses the long term fuel calibration numbers in open loop.
