I replaced the following items on a friend's '02 Lexus ES300 today:
and added ARX to the power steering and the transmission. I also flushed the coolant. After the job, the Vehicle Stability Control light came on, along with the Traction Off warning and the Check Engine light. I disconnected the battery for 10 minutes, and it went away. I drove it around for 10 km or so and it was off...until I switched off the engine and restarted it. First the CE light comes on, followed by the other two. Anything obvious I should check before an OBD-II? Thanks!
- Timing belt
- Crankshaft seal
- Camshaft seals
- Spark plugs
- Water pump
- Thermostat
- Radiator hoses
- Radiator cap
- PCV valve
- Air filter
