I dumped an entire (12ounce) bottle of Redline Waterwetter into my radiator after doing a coolent change. Then I read the back of the bottle and it says use 1ounce of waterwetter per quart... Oops! My cooling system only holds 4.5 quarts, it seems like I've added around 4 or 5 times the recommended dosage of waterwetter. Will it do any damage having so much WW in my cooling system? Do I have to drain some coolent out and re-dilute?
