I replaced the o2 sensor in my friend's truck because the mode $6 test results showed that it was on the verge of failing.
The new o2 sensor definitely improved the test results and the truck runs better.
The old o2 sensor had some carbon deposits on it.
I decided to take the o2 sensor and do the propane torch test with it: Connect it to a multimeter, put it in the flame, and see what the highest voltage it produces is. It got up to .8V and dropped to 0V instantly upon removal from the flame. I think this indicates a good sensor.
This also cleaned all the carbon off the sensor.
Has anyone used a propane torch to test/clean an o2 sensor? I'm wondering if this sensor will work better now. It got red-hot while it was in the flame.
