Railroad observation is interesting, but riddle me this? Why do my sprockets wear out? And why, when I have my sprockets hard coated with an industial solid lube do they last at least twice as long?
Turn the "way back" dial to when oring chains first came on the market. Afraid to say I'm codger enough to have been around. They were marketed as "lubeless" chains are better than sliced bread. Guys bought them and didn't touch them with oil only to have sprockets wear out and kinks in the links. The benefits were there, but they quickly learned they still needed some maintenance, maybe not the slobbering and soaking in witches brew of the old chains, but some attention was required.
Chains wear because the pins wear, that's why they get longer and start to mismatch the pitch of the sprocket. Pins wear because of lack of lubrication. There IS grease installed at the factory before the links and orings are fitted, often with a vacume process. Not sure why anyone would think they are made dry?
Screwin around with different chain lubes is part of the rites or motorcycling IMO. I wouldn't try and influence anyone in what to use or not use and cheat them out of all the fun I had through the years. Before o ring chains this topic would have all sorts of weird tricks and tips posted.
