Purchased new, now has 111,000 miles. Had the local quick lube use YB 5W20 (as required by Honda)every 4 - 5K miles until about 75K miles then decided to take over the oil changes myself and have used M1 5W20 and M1 filter since but still used 4 - 5K OCI's until I discovered this site. The engine appears very clean when looking into the sump, though I read here somewhere that Honda V6 engines are hard on oil. The Accord seems to purr with the M1 and I've been happy with it. I run 80% - 90% highway at 60+ MPH. It doesn't burn any oil between changes and actually seems to run better after the M1 has a couple thousand miles on it. I am thinking of changing to M1 0W20 to help with any start up wear, but would like to hear what some of you say. Valvoline Max-Life since over 75K? Pennzoil HM, Mobil HM? Would a HM oil do any good since the M1 seems to work well and has generally had reasonable OCI's its whole life? Would a different weight be beneficial?
Am looking for:
1.) Engine protection (would like to exceed 200K)
2.) 7,500 OCI's
I have not done a UOA, but am planning to when I dump this oil around 6K. I've search the site, but most Honda info is for 4 cylinder models. Sorry for rambling, just looking for suggestions from people smarter than me about this.
Am looking for:
2.) 7,500 OCI's
