Bringing an old tread but I wanna give you my experience!
I did it the first time today on my car.. long story short:
My gf's toyota echo is getting the check engine light for about 2 months now and I'm getting the engine is running too lean or about. After checking on the net, I found out that t could only be related to the maf sensor. Before cleaning the maf on the echo and messing it, I said to myself, I'm gonna try it first on my car so if I cant do it, I'll pay the dealer to do my gf's car.
I cleaned mine very easily and turns out it was dirty a lot + I did clean the throttle body. I used the crc maf sensor cleaner for the maf sensor and the intake cleaner for the throttle body.
WOW, what an easy job to do + the throttle response a little bit better + no more rough idle when the car is cold.
Also, I had a problem when the car was in overdrive and I was letting off the gas pedal between 40 and 55 mph, the rpm would surge up and down between those mentioned speed. Guess what, no more surging! Also, the transmission would normally hesitate between the 4th gear and the 5th one when half throttle was applied but not anymore!!!!
I'm so happy guys, you just can't imagine!
Also, when taking apart the maf sensor, I found out that my air box (the black box with the engine air filter in it) was not sealed properly. There was a little space left between the air filter gasket and the box itself. I fixed it!
Thanks a lot again!!!
The happiest man ever: - Mark.!
