OVERKILL
$100 Site Donor 2021
Originally Posted By: robertcope
Originally Posted By: Pablo
You have a point. I assumed the Manganese came from heavy use of fuel additives ie "Octane boosters".
Oh, you know what, that may be the case. When I first got the truck, it pinged like crazy under load. I can't recall what brand of booster I used (I want to say Lucas, but... I'd have to go look it up), but I did put some in for a few tanks to see if it helped the pinging. As it turns out, that's a common issue with he TRD SC setup, and you can either upgrade injectors and whatnot or just drive it easier at low RPM... apparently the ECU won't retard timing until after 2500rpm. Some day I'll do the fuel upgrades.
robert
That sounds hokey, you can't just get it tuned? Pinging = bad.
robert
