I was reading the thread where someone was trying premium fuel to see if there was any/enough fuel economy increase to justify such fuel.
There were many quotes from owners manuals about fuel grades.
Which reminded me of thoughts I've had before, but never really did the research, so here goes.
In places like Denver, CO, the "regular" grade gas isn't 87, but 85 octane (R+M)/2.
I don't recall ever seeing an owners manual give adjustments for octane at higher elevations. Yet I suspect most folks fill with 85 in locations where that's the regular grade.
I understand the theory behind it. I may not have the vocabulary correct, but effectively, since the air is "thinner" there is less likely hood for pre-ignition at higher elevations, so a lower octane fuel is sufficient.
But is it really OK with respect to the car makers? Since their recommendations are for 87 or 91 octane, depending on the car, what is the position on using such fuel in higher elevation environments?
I've driven out there before and usually try to fill up with the higher grades when I leave so as I drop to lower elevation, I'm not sitting on a tank of fuel that is 85 octane.
But I doubt most folks really think about it, and their cars manage to survive.
Any thoughts?
Any thoughts?
