I can't seem to pull any gas up to the sparkplug in the cylinder.
I have pumped gas up to the carb with the primer bulb and upon removing the top cover of the carb, can see gas emerge when the small rocker valve at the top of the carb is depressed.
So my question is, if I have gas at the top of the carb inside, why can I seem to get any gas out of the carb.
Is anyone familiar with the inner workings of this poulin carb. I can't see what causes that rocker valve to release gas. I do see a rubber diaphram which installs over the carb so is it maybe vacumn which opens the gas flow?
I have good compression. The rubber manifold looks new. All gas lines look good.
Any suggestions are appreciated.
