Originally Posted By: wavinwayne
The router is in a locked server room, to which I am not allowed ANY access. So, any modifications or add-ons to the router are out of the question. I was wondering if there was anything I could do to make the wireless signal stronger in my office only.
The only way you could affect signal strength in your office is by putting a repeater between your office and the router or by making a change at the router itself (bigger antenna, relocated antenna, etc.). If this is an office WiFi system and your office doesn't have good enough signal, then I think you should pester the IT guys to put a better antenna on the router. Having it physically in a closet is pretty bad- they should at least get the antenna out in a hallway.
