Just for fun, I graphed Valvolin Synpower 5W-20 and Valvoline Synpower 5W-40(used 5W for both for fairness) Up to an oil temp of 181F, the 5W-20 is in the viscosity range of a 40 grade(and higher). As temp goes up, it goes into the viscosity range of a 30 grade then to a 20 grade.
I have used Mobil 1 15W-50, in every vehicle since 1990. Some of them specked MUCH lower viscosity grades. All of them gave better than EPA average MPG, none used, leaked, or even seeped any oil. All started with no problems in Northern VA, Southern OH, Eastern KY and Northeast TN. Never an engine problem of any kind. All had engines running perfectly when traded at an average of about 180,000 miles. One with 261,000 M1 15W-50 miles, one with 214,000, still in daily use.
I have great doubt that there is any time difference in pumping up to upper engine parts. I was adjusting valves on a motorcycle engine that used 20W-50 oil. The engine was at ambient temperature and I had my wife turning the engine by hand, very little at a time. Even those much less than one complete turn gave oil being pumped out around the cam bearings. The same thing on a 1986 Toyota 22-R engine with Castrol 20W-50 and M1 15W-50, except we clicked the starter.
If a van engine calls for a 5W-20 and gives an EPA estimate of 24 MPG, and you use 15W-50 and average 27 MPG....what to think.
