Current grease is white. Toyota told me it is white lithium based. That was the most detail they could give me. I'm not going to pull the hub apart which will make cleaning and repacking difficult. I had to remove the hub to get access to the strut bolts. I cleaned out the old grease which wasn't lubing anything so I can now see the ball bearings and the inside retainer. I want to replace the grease I removed and try to work it into the bearing as best I can.
Anyone know what grease will be compatible? Thanks.
