Originally Posted By: 4x4taco
Did some searching around. I'm going to use either Permatex's Silicone disc lube or their new primo ceramic lube. Totally forgot about that stuff... I've been away from cars to long. Either one of those should be more than enough. I'm at the 41k mark and bought the car used a few weeks ago. Looks like the previous owner/dealer just threw pads on it. Brakes kinda drag when you spin the wheel compare to what I'm used to. Just need a good brake Inspection/overhaul. Turn the rotors or replace them if to thin. Flush about 2qts of Synpower Dot 3/4 through it, and clean the slides up and spray the pads down with the quiet tack spray. Back in business in no time. It's really amazing how many shops/people to shabby brake jobs. I've always done mine like they were brain surgery. I torque every bolt down, anti-size, Syn caliper lube, spray etc. I'm crazy with it. Get my rotors down to less than .003" of runout.. I've always had good brakes on my car. Not sure why others neglect brakes so much.
No need to use disc brake quiet spray if the pads have shims, which most do.
