Originally Posted By: javacontour
My router remembers devices so unless I exhaust the internal addresses, I get the same one anyway.
If you are not using a dozen different devices each day, then you will most likely get the same address for each device when it returns to the network.
My router (a Linux box) has dhcp entries in the table that it handed out over a year ago, for devices that have not been plugged into the network since then. If I take one of those devices and plug it in right now, it will get the same IP it had over a year ago.
So, for all practical purposes and intents, I don't need to assign static DHCP entries.
If it DOES start to run out of IPs (with over 100 IPs, not likely to happen), it assigns the stalest IP lease first.
I don't know how well it works when the router has no nonvolatile memory with which to store the DHCP table. Cisco routers (the ones that run IOS, not the Linksys stuff) have a way to store the DHCP table on a tftp server.
