Hi all. Had my high pressure hose blow out of the coupling with the master cylinder. Fluid got pretty much everywhere in the engine area, looks like it drenched a couple of wire connectors. What is the best way to clean this stuff off? Go easy with the hose? Wipe it all down by hand? Also, where can I get a factory service manual (dealer only I assume?) Thanks for helping a newbie out!
Mazda 6 2005....
I sprayed it slightly with some water ... I guess it should be fine ?
Mazda 6 2005....
