UPS package tracking is so confusing!
by Klutch9
40 minutes 16 seconds ago
Dupont non-stick lube
by buck91
45 minutes 52 seconds ago
House electrical wiring question
by road_rascal
46 minutes 12 seconds ago
Air pressure question
by aquariuscsm
49 minutes 12 seconds ago
Fllow the DOT's
by WyrTwister
Today at 07:23 PM
Auto Rx?
by coopns
Today at 06:54 PM
Rotella for 6.0L Gasser
by Joefuskie
Today at 04:40 PM
Pennzoil Platinum Euro 5W-40
by 1JZ_E46
Today at 04:21 PM
TGMO 0W20 7700 miles UOA
by micmac
Today at 03:45 PM
"Low Coolant" light doesn't vanish.
by OpenClose
Today at 02:07 PM
Is running "Engine flush" before a change legit?
by OpenClose
Today at 01:59 PM
Who Owns A Beater?
by Red91
Today at 01:09 PM
Dmax7901, carver1, Handy7rick, sicilien, Crater_77
57738 Registered Users
89 registered (97f150, 2004tdigls, 06AllAmerican, 01rangerxl, 69GTX, 2015_PSD, 7 invisible), 1615 Guests and 97 Spiders online.
57738 Members
66 Forums
248227 Topics
Page 1 of 7 1 2 3 4 5 6 7 >
#1581337 - 08/28/09 02:20 PM Just did water decarbonization on Mazda 3
Greggy_D Offline
Loc: Near Ann Arbor, Michigan
WOW!!!!!
My 2007 Mazda 3i has 42,000 miles on it. I have owned the car 3 years next month. The car has seen a steady diet of FP60, Regane, Lucas UCL, and MMO (obviously not all at once). I decided to do a water decarb to see if there was any difference in the car.
Took her out for a short 15 minute spin first to heat the engine. Hooked up 8 feet of 3/8 inch fuel line to the brake booster nipple. Sat in the drivers seat with a gallon jug of distilled water and ran the open end of the hose to my location.
Started the engine and dipped the tip of the hose into the water. Kept the RPMs at 3000. Got into a rhythm....dip the hose for a split second...raise it for half a second or so.....dip it back up.....raise it instantly back up.
I went through about half a gallon of water in 3 or 4 minutes. I could see smoke out the pipe when I first started but near the tail end of the run I couldn't see anything.
Turned the car off and disconnected the negative post for a few minutes to reset the ECU. Reattached the brake booster line. Went for a drive to dry her off and WOW!!!!
Man she is unbelievably responsive now, just like the day I drove her off the lot. I always wondered where in the heck my power went as the years went by. At idle, you cannot hear or feel that the car is on. It's just crazy.
After a 20 minute highway drive I pulled back home. Looked at the oil filler cap and saw just a small amount of milkiness on the inside of the cap. I figure it's just some condensation. The oil on the dipstick is still good looking. I'm going to change the oil out tomorrow morning just to be safe.
I highly recommend this IF YOU GO SLOW. You COULD possibly hydrolock your engine if you suck in too much water too quickly.
Greggy D.
#1581345 - 08/28/09 02:32 PM Re: Just did water decarbonization on Mazda 3 [Re: Greggy_D]
Ndx Offline
Loc: IL
I would love to do this with my 3 but I'm to afraid of Hydro lock ... any other safe ways to do it ...
#1581350 - 08/28/09 02:36 PM Re: Just did water decarbonization on Mazda 3 [Re: Ndx]
pickled Offline
Loc: The Rocky Mountains
Nice work...and you didn't have to pay $10 for a 16oz bottle! I figure that if I did this with my ford I would use San Pellegrino for it's exquisite mineral content.
Edited by pickled (08/28/09 02:36 PM)
Used gear lube and burnt ATF is all the cologne a real man will ever need!
Too many toys and automotive parts to list...
#1581362 - 08/28/09 02:46 PM Re: Just did water decarbonization on Mazda 3 [Re: Ndx]
Greggy_D Offline
Keep the RPMs at 3000 to atomize the water. Just barely dip the hose in the water for a split second and then take it out for a second. Repeat.
I wish I could see the internals. What blows my mind is how much a difference there is even after using a steady diet of fuel adds.
Greggy D.
#1581363 - 08/28/09 02:48 PM Re: Just did water decarbonization on Mazda 3 [Re: pickled]
Greggy_D Offline
Yep....69 cents for a gallon and from what I understand water works better than Seafoam, GM Top End, B12, etc.
Greggy D.
#1581365 - 08/28/09 02:51 PM Re: Just did water decarbonization on Mazda 3 [Re: Greggy_D]
bepperb Offline
Loc: Milwaukee, WI
"any other safe ways to do it"
Get a metal needle one would use to fill a football or basketball. Put the end of the hose around that, and dip that in the water. It will slow the rate of flow obviously.
I'm not sure how far up the line the brake booster is, but obviously you want to be as far upstream on the intake as possible but after the MAF (if you have one, I don't know).
I might prefer seafoam, but it's hard to beat free.
Edited by bepperb (08/28/09 02:53 PM)
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#1581367 - 08/28/09 02:53 PM Re: Just did water decarbonization on Mazda 3 [Re: bepperb]
Johnny248 Offline
Loc: Detroit, MI
mixture of water and kerosene works even better.
'11 Ram 1500 5.7L
'08 Beetle 2.5L
'06 Eclipse GT 3.8L
'95 Four Winns Sundowner 5.0FI
'94 Honda Dio 72cc Big Bore
#1581378 - 08/28/09 03:00 PM Re: Just did water decarbonization on Mazda 3 [Re: Ndx]
addyguy Offline
Loc: Canada
Unhook/open your air intake tube. Use a spray bottle (ie, Windex bottle) filled with water. Spray water into the intake tube, while revving the engine manually with the throttle cable. That's what I do on my 2002 Cavalier, and it works well. I'll be doing this on my car vey soon, as I'm due for my emission test very soon.
Agree with the OP; you DO feel a difference in the way the car runs after doing this.....
2003 Mazda Tribute LX V-6, 196,850 miles...DEAD.
MM F1 5W-20 conventional + Bardahl + top-offs.
MM MPH2 filter.
#1581381 - 08/28/09 03:03 PM Re: Just did water decarbonization on Mazda 3 [Re: addyguy]
Greggy_D Offline
No throttle cable. It's fly-by-wire.
The brake booster nipple is right after the TB and right before the manifold. Has a red lockdown ring on it. Can't miss it.
Greggy D.
#1581400 - 08/28/09 03:14 PM Re: Just did water decarbonization on Mazda 3 [Re: Greggy_D]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
Spraying hot water into the throttle body with a spray bottle works great for me...
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1581428 - 08/28/09 03:29 PM Re: Just did water decarbonization on Mazda 3 [Re: Greggy_D]
d00df00d Online   content
Loc: PA
Please keep us posted in a few hundred miles when the ECU has had a chance to adjust. I'd be interested to know if just resetting the ECU had any effect.
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#1581433 - 08/28/09 03:34 PM Re: Just did water decarbonization on Mazda 3 [Re: StevieC]
Vikas Offline
Loc: NorthEast
I tried to spray water through cab using Windex bottle on my lawn mower; I could not find a vacuum hose. Unfortunately, it was a complete failure as the lawn mower promptly died and took lots of pulls before it fired up again. I was very careful in spraying the water. It was room temperature water though.
Generally, the engine is very difficult to stall when I spray carb cleaner or Seafoam Deep Creep through the carb. I really have to lean on that spray button before it will complete sputter and die. I was quite scared when the single puff of water killed the engine and was so hard to restart.
- Vikas
Edited by Vikas (08/28/09 03:36 PM)
#1581442 - 08/28/09 03:38 PM Re: Just did water decarbonization on Mazda 3 [Re: d00df00d]
Greggy_D Offline
I tried resetting the ECU back in the Spring. No change. This procedure today did wonders.
Greggy D.
#1581461 - 08/28/09 03:50 PM Re: Just did water decarbonization on Mazda 3 [Re: Greggy_D]
Loc: PA
Aha. Alrighty then. :)
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#1581486 - 08/28/09 04:08 PM Re: Just did water decarbonization on Mazda 3 [Re: d00df00d]
KLowD9x Offline
Loc: Lugoff, SC
The brake booster line is pretty large for this procedure.
I always used the smaller vacuum lines for the emissions system (something really small, like 1/8" ID) to keep the flow low.
1993 Volvo 850 2.4i (280K miles, Valvoline Maxlife Full-syn 5w30)
2004 Volvo S60 2.4i (130K miles, Mobil1 0w40)
