Mobil1HM 10w-30 vs. 10w-40 in reducing leaks
by 2James1
05/05/16 10:56 AM
Is this a decent price for a Honda mower
by chiefsfan1
05/05/16 10:31 AM
Generator special of the day HD
by LotI
05/05/16 10:15 AM
'15 Ecodiesel, Pennzoil Ultra Euro L 5W30, 8,330mi
by mhadden
05/05/16 09:46 AM
JSB Great Bearings
by artbuc
05/05/16 09:33 AM
fuels and GDI
by novadude
05/05/16 09:23 AM
P0158 2000 Jeep Cherokee 4.0
by Miller88
05/05/16 09:05 AM
Fort Mac is on fire
by Trotter
05/05/16 08:50 AM
SAE 10 motor oil?
by FordCapriDriver
05/05/16 08:39 AM
Jaguar XE?
by Quattro Pete
05/05/16 08:31 AM
subaru head gaskets and coolant
by rogerbeck
05/05/16 08:30 AM
High ZDDP oils in newer cars that do NOT use oil
by Dad2leia
05/05/16 08:29 AM
02Maxima, xlittoninjax, Jamer, johaiti, Danielbaja
57803 Registered Users
101 registered (4wheeldog, 1JZ_E46, 440Magnum, 69GTX, 2James1, 6 invisible), 0 Guests and 0 Spiders online.
57803 Members
66 Forums
248507 Topics
Page 1 of 2 1 2 >
#1579515 - 08/26/09 08:00 PM Tie-rod end stud nut torque spec; important?
Nick_Escalante Offline
Loc: RI, USA
I was having a conversation with a few people about my tie-rod ends and told them that the Haynes manual spec torque on the stud nut was 27 lbs-ft. They told me just tighten it down very tight. What would be the best thing to do? thx.
#1579521 - 08/26/09 08:05 PM Re: Tie-rod end stud nut torque spec; important? [Re: Nick_Escalante]
tomcat27 Offline
Loc: Midwest
gee, I've never used a tourque wrench for that... you'd need a crow's foot to adapt a torque wrench to it anyway.
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1995 Jeep ZJ, 1970 Cougar, 2010 Vstar, 1989 Radian
#1579522 - 08/26/09 08:07 PM Re: Tie-rod end stud nut torque spec; important? [Re: Nick_Escalante]
Papa Bear Offline
Loc: Leamington, ON, Canada ..... r...
Those after-market manuals often have erroneous info. I would refer to a factory service manual and do what it says.
I never was too bright - now old age and forgetfulness complicate things as well" crazy
2016 Dodge GC deep cherry CVP drive
#1579527 - 08/26/09 08:10 PM Re: Tie-rod end stud nut torque spec; important? [Re: Papa Bear]
Loc: RI, USA
FSM is 27 lbs-ft, Haynes is correct.
Edited by Nick_Escalante (08/26/09 08:18 PM)
#1579542 - 08/26/09 08:19 PM Re: Tie-rod end stud nut torque spec; important? [Re: Papa Bear]
rpn453 Offline
Loc: Saskatchewan
That sounds about right. I'd go with the torque spec.
I've never needed to use a crowfoot to torque a tie-rod, though maybe some designs require it.
2004 Mazda3 GT Hatch 75k
#1579551 - 08/26/09 08:25 PM Re: Tie-rod end stud nut torque spec; important? [Re: rpn453]
bdcardinal Online   content
Loc: Santa Barbara, CA
if you have a inner tie rod tool you can torque them properly if its a rack and pinion style.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#1579640 - 08/26/09 10:00 PM Re: Tie-rod end stud nut torque spec; important? [Re: bdcardinal]
The Critic Offline
Loc: Walnut Creek, CA
No offense intended, but if you do not know what 27 ft-lbs feels like, you should not be wrenching on cars.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#1579675 - 08/26/09 10:41 PM Re: Tie-rod end stud nut torque spec; important? [Re: The Critic]
Junior Offline
Loc: Iowa
And why is that? A torque wrench or two is a very good investment for any shade tree mechanic. Better to have the correct tool for the job.
#1579709 - 08/26/09 11:32 PM Re: Tie-rod end stud nut torque spec; important? [Re: Junior]
The Critic Offline
I own torque wrenches and I use them. However, if a person does not know what 27 ft-lbs feels like, they should not be wrenching on cars. Knowing what 27 ft-lbs feels like (or whatever you are torquing to) is critical in case of a torque wrench failure.
#1579740 - 08/27/09 12:06 AM Re: Tie-rod end stud nut torque spec; important? [Re: The Critic]
1993_VG30E_GXE Offline
Loc: Ontario, Canada
No offense intended, but anybody who claims they are a human click wrench is a fool and talking out his a hole.
#1579743 - 08/27/09 12:08 AM Re: Tie-rod end stud nut torque spec; important? [Re: Junior]
Yes, ALWAYS use a torque wrench and don't listen to this dude. He's talking out his bum. In fact you should have 3 to cover the whole range. 1 big one for axle nut. One in the middle say 10-150 ft-lbs. Then one for inch pounds.
Don't ever guestimate. Only hicks do that sort of stuff.
#1579936 - 08/27/09 09:05 AM Re: Tie-rod end stud nut torque spec; important? [Re: 1993_VG30E_GXE]
Vikas Offline
Loc: NorthEast
Well, he does have a valid point. Anybody wrenching on the car needs to be able to differentiate between
1) How tight spark plug should be ~15 ft-lb
2) How tight lug nut should be ~80 ft-lb
3) Everything else ~40 ft-lb
*without* absolutely needing a torque wrench. Obviously, there are special cases where a torque wrench is a must but majority of car repairs can be done without torque wrench.
To take this particular tie-rod end case, ff instead of 27 ft-lb, it was torqued to 40 ft-lb, nothing bad will happen. On the other hand if it was torqued to 15 ft-lb, there will be a disaster waiting and if it was tried to torque to 80 ft-lb, the threads might get stripped. So, you don't need to know how 27 lb-ft feels like but you better know that it is in between a spark-plug and a lug nut. If you can't, you should not be wrenching on cars.
- Vikas
#1579973 - 08/27/09 09:45 AM Re: Tie-rod end stud nut torque spec; important? [Re: The Critic]
KrisZ Online   happy
Loc: Toronto, Canada
I know what 27.5 ft-lb feels like, do I win?? tongue2
But seriously, are you serious????? Then would you care to explain why mechanics with years of experiance that wrench on cars day-in-day-out still use torque wrenches? And you say that, as a shade tree mechanic, you know how 27 ft-lb fells like???? Give me a break LOL
I don't use a torque wrench for every single bolt and nut and I have a general feel of how tight things should be, so I probably could put this tie rod between 25-35, but to say that if you don't know how 27 ft-lb feels, you shouldn't be wrenching is ridicuolus.
Edited by KrisZ (08/27/09 09:50 AM)
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#1580013 - 08/27/09 10:23 AM Re: Tie-rod end stud nut torque spec; important? [Re: KrisZ]
Trav Offline
Loc: MA, Mittelfranken.de
The correct torque is important,if it wasn't why even bother with specs,instead just say tighten until almost busted.
Granted there are many parts than can be done by experienced "feel" but critical parts must be torqued to the proper specs,these include brakes,wheels,suspension,critical drive train components and all engine parts except maybe accessory items.
If the car uses an aluminum knuckle its an absolute must that the correct spec be adhered to.They can develop hairline cracks or spit if wrenched on to hard leading to a catastrophic failure.
We have 2000 chevrolet Venture here with a split in the tie rod area of the knuckle,some tire and alignment shop put the new tie rod end on with an impact.Now it needs a new knuckle.
IMO you cant do yourself any bigger favor than owning a few quality torque wrenches if your going to be doing your own wrenching.
Also google for the effects of lubricants,thread lockers,extension bars etc and how they effect torque.
#1580040 - 08/27/09 11:10 AM Re: Tie-rod end stud nut torque spec; important? [Re: Trav]
Eddie Offline
Loc: Florida, Cape Coral
When I was younger, I practiced tighting a nut and check with a torque wrench and got quite good at getinng to + or - 15%. Not as good today for sure and I use a torque wrench on critical items like cyl heads, brake parts. 27 ft/lbs is a good snug with a 10 inch wrench.
CX5 Touring 2.5L :-)
Page 1 of 2 1 2 >
