1997 Honda Civic LX Sedan
Oil: Amsoil Signature Series 0W-30
Oil filter- Amsoil EaO20
Air filter- Wix
Total miles on vehicle = 143,314
Miles on oil = 8,319 Miles
Make up oil= None
Fuel Treatment: FP3000 in every tank
I decided to go ahead and include the results from my last OCI with the Penzoil Platinum 5W-30 for comparison to the Amsoil Signature Series oil. The analysis was done by Oil Analyzers, Inc.
Here are the comments in the report: Data flagged for observation only; Viscosity is SLIGHTLY LOW; Please provide unit model number so we may compare data to the proper standards for this unit.
My final comments: The data OAI flagged was the [email protected] . The only thing I did different between the two OCIs was running the FP3000 at three times the recommended rate in the Amsoil SSO. I wanted to see if there would be a benefit to the higher treatment rate. Did the higher FP3000 dosage cause the higher fuel dilution of 1.3% in the Amsoil? My brother is PP guy while I am an Amsoil fan. This current report caused my brother to do some crowing about how PP was comparable to Amsoil yet in spite of this result I still like and will continue to use Amsoil. Funny, isn't it?
The first column was the Amsoil@8,319 miles and the second column was the Penzoil Platinum@7,541 miles. Any thoughts or comments?
Aluminum 2----------0
Chromium 0----------0
Iron 6----------------5
Copper 9-------------6
Lead 12---------------10
Tin 1-----------------0
Molybdenum 11-------56
Nickel 0--------------0
Manganese 0---------0
Silver 0--------------0
Titanium 0----------0
Vanadium 0----------0
Antimony 0----------0
Lithium 0-----------0
Potassium 0---------2
Boron 11-------------33
Barium 0------------2
Silicon 15-----------17
Sodium 11------------5
Calcium 3109-----------3236
Magnesium 13---------14
Phosphorous 593-------779
Zinc 717--------------936
CSt Visc. @ 100C 9.2----10.3
Fuel (%) 1.3%----------------- Water (%) TBN 4.95---------------------5.38
Soot Oxidation 42----------------21
Nitration 25----------------24
Air filter- Wix
Make up oil= None
