Can you mix G05 and Dexcool???
Maybe, in an emergency, just for topping up. Did you read the last line in the comment section?
Depends on what you mean by 'compatible'. This isn't a question with a distinct 'yes' or 'no' answer.
If you trust Prestone, then you could say that their all-makes dexclone coolant is "compatible" with everything under the sun. So they're essentially saying that dexcool is "compatible" with every coolant in every vehicle ever made. Does that make it a good idea? I have my doubts.
Also, notice the caveats from your article. They aren't exactly confidence-inspiring:
Quote:
*Do not use SCA with conventional high silicate antifreezes
**Requires special silicate additive liquid or silicate filter to protect certain gasket materials
***Mixing different types of antifreezes can reduce their corrosion protection. Engine manufacturers recommend a 10% limit on mixing coolant types.
So yeah, you can mix them. And probably nothing will come of it. But considering Dexcool's long and sordid history, why would you even CONSIDER doing it??
The "mixing" of coolants is the most overblown issue on this website and on others too.
Everything you need to know about coolants is here on this page:
http://www.aa1car.com/library/2004/us120426.htm
I still have yet to hear a *reason* coolants can't mix.
Audi, that Larry Carley article does NOT recommend mixing different coolant chemistry. He says it is ok to top off different coolants with UNIVERSAL coolant. There's a difference. That article is aimed at service garages wanting to consolidate their inventory, not maximize cooling system life.
In this Larry Carley article, he reinforces these concepts:
http://www.aa1car.com/library/coolant.htm
"GM warns that intermixing extended life coolant with ordinary coolant reduces the coolant's life to that of the ordinary coolant."
"To reduce confusion, several antifreeze suppliers (Peak and Prestone) now sell a "universal" type of antifreeze that is compatible with all types of antifreeze and all makes and models of vehicles. Some argue this is not entirely true, but the stuff seem to work okay and is widely accepted in the aftermarket."
"When adding or changing coolants, therefore, the best advice is to follow the recommendations of the vehicle manufacturer. Replace same with same, if possible, using the same type of antifreeze that was in the system. Or, use a universal coolant that is approved for ALL applications.
Regarding your last statement, in this article, Paul Weissler gives one reason NOT TO MIX COOLANTS:
http://findarticles.com/p/articles/mi_qa3828/is_200408/ai_n9453107/pg_3/?tag=content;col1
"Sure, for small top-ups or in an emergency situation, it doesn't matter-use what you have. However, there are possible problems with extreme mixtures. An example cited by one coolant chemist: A somewhat diluted mix, perhaps 50% to 60% water, with the remainder (from top-ups) a 50-50 combination of an OAT and a conventional American coolant or a G-05. A remaining inhibitor (borate) could attack aluminum if the silicates are depleted."
I, too, would like scientific results showing the results of mixing coolants. Until then, I will err on the cautious side based on the best info available (not anecdotal stories on BITOG, including mine).
Here's Ford's position on universal coolants:
http://www.search-autoparts.com/searchau...e/detail/329982
Just their opinion, mind you:
"Based on blind laboratory ASTM testing performed in duplicate, two leading "universal" coolants currently in the marketplace did not meet the extended D2809 requirements of Ford's Motorcraft Premium Gold Engine Coolant specification, WSS-M97B51-A1."
"Use of non-approved "universal" coolants may lead to eventual engine damage or failure. Problems caused by use of non-approved "universal" coolant may not arise immediately, but may occur over longer periods of time due to additive compatibility issues."
