Hello, Have a 2002 Silverado 5.3 4X4 extended cab that I have owned since new. Has been gently driven and only synthetic oil every 5-6k. This weekend after towing some moderate cargo on a trailer up some long interstate hills (I68 from WV into Maryland), engine was worked pretty good. After sitting all night I now have a leak about as big as a saucer under the transfer case. Can't tell if it's oil, tranny fluid, or transfer case fluid. It does come from what does look to be a rubber vent hose that exit's just above the transfer case,the oil then dribbles down over transfer case. Seems like this hose runs forward over the top of tranny up by the bell housing, where I loose track of it. Anyone have any idea what this hose connects to and why it might be leaking??
I have never had ANY leaks or trouble with this truck. Don't think its tranny fluid as it doesn't seem to have that smell. Thanks, Tom
