BK44 Power Enhancer. What next?
dallas, tx
I recently tried BK44 Power enhancer which has definitely given me a 1.5 to 2 mpg increase and that's with the airconditioner running (I live in Dallas). How long can I realistically expect this increase in mpg to remain? How often should I use BK44? Should I follow this up with MMO or Lucas UCL or what? Any comments are appreciated? Thanks.
BG44K tells you:- "After cleanup with BG 44K Power Enhancer, regular use of BG Supercharge II, Part No. 202, in gasoline engines"
I would just monitor the car's performance and efficiency and see if the improvement is permanent. And I would definitely update this to let rest of us know :)
- Vikas
if your using a good top tier fuel or something like bp,you should be good for quite some time.even with out additives.
If you noticed a difference, then you went too far without it.
How many miles do you have? any other FI cleaners ever used?
There is no followup needed.
I do toss in a bottle of FI cleaner with every oil change or two when I remember. I rotate among the brands.
BG44k is one of the best.
