::Look - Up in the sky!!::
Is it a bird? Is it a plane?
No, it's TIREMAN! Strange visiter who lives eats and breathes TIRES. Who knows what a sidewall says without actually looking at it. And who will sometimes clear up many misconceptions about tires - which he is about to do now::
Badlees:
You picked up LT245/75R16 Load Range E tires - a very common size for heavy duty pickup trucks - F-350's and C/K3500's. They are indeed 80 psi tires.
However the placard on your truck calls for P245/75R16's. These are 2 different animals! Let me give you an example.
At 35 psi, a P245/75R16 is rated for 2271#, but since it is being used on a pickup truck, it has to be derated 10% = 2065#
An LT245/75R16 at 35 pai has a load carrying capacity of 1700# - and it doesn't need to be adjusted because it was designed for use on trucks.
What's this mean?
That if the placard calls for 29 psi for a P245/75R16, in order to get the same load carrying capacity, an LT245/75R16 needs to use 38 psi.
