Now that I have been convinced to stay away from fram, I need to know what else is out there. What is a decent in expensive filter that I could. Use on a 3k oci? I thought of k and n but that would be on the high sisde a bit
While Fram will not destroy your vehicle, you can pay a lot less for an oil filter.
Supertech. The low end napa is good too. Purolator premium plus is cheap right now from Amazon.com, if you don't mind ordering.
SuperTech, STP, Quaker State, Fram (If you get them for 50 cents like I did!), Pennzoil, ProLine, Napa ProSelect, MotorCraft, AC Delco, Purolator Classic (Premium Plus), Parts Plus, Carquest Red. Any of those filters would work fine for a 3k OCI.
If your filter is a large, common number, I would look at ST. Their smaller ones have a cheap dome end bypass, as does everything made by Fram and Purolator except Motorcraft. I am still looking for a good, cheap replacement for the ST 3950 Wal-Mart dropped. They had already cheapened it with a dome end bypass. Next oil change, it is going to be STP, Pronto, or Hastings.
