Originally Posted By: badtlc
I got an Escape (2007 XLS) and when it is warm under the hood and it gets started, the belt and AC make noise when the ATX is put in Revers or Drive. Once it drives a few hundred feet the noise goes away.
The belt looks fine. Would some sort of non-stick spray work for this?
Let me see if I understand.
You tell us this, and then you tell us we are wrong.
Our web based diagnosis is only as good as the information given
On a more serious note, I'm glad you've figured it out.
