OVERKILL
$100 Site Donor 2021
Originally Posted By: CATERHAM
Measuring boundary lubrication friction of valve train shims at very low rpm's may be interesting but falls far short of the entire picture of engine wear as a whole.
UOA measures engine wear in its totality.
And a snippet from Doug's article:
Originally Posted By: Doug Hillary
By Doug Hillary
UOAs are a great tool in the Management of any machinery that uses liquid lubricants. Unfortunately, their real value is often misunderstood by those who contribute to BITOG.
Firstly, it is important to realize that you get what you pay for. The most common forms of UOA are limited in their scope. It is a case of if you pay more you get more. So my comments here relate primarily to the “simple” UOAs – the cornerstone of those appearing on BITOG
Secondly, it is easy to assume that by carrying out a UOA you will be able to determine how quickly the engine is wearing out. As well, if you change lubricant Brands you will be able to compare the wear metal uptake results and then make a balanced best lubricant choice to make your engine last longer.
Sadly that logic is seriously flawed.
Single pass (random) UOAs will provide some information regarding wear metals but unless you have a history of your engine’s performance up to around 1 million miles the results are simply that – UOA results! As an example a limit of 150ppm of Iron is a reality – after say 100k it means the lubricant should be changed and all is well. But what is the situation if you have 150ppm of Iron at 5k? Where would you look what would or could you do? So UOAs are really a diagnostic tool – one of many!
The other parts of the UOA Report will be much more valuable to you – it will tell you about the CONDITION of the lubricant and its suitability for further use. This will enable you to get the maximum safe use from the lubricant saving a valuable resource in the process.
And another little part worth mentioning from the article:
During the last 50 or so years I have carried out hundreds of UOAs on all sorts of engine configurations – and on transmissions, gearboxes and differentials. These were done in consort with four Major Oil Companies (Shell, Exxon-Mobil, Castrol, Chevron-Caltex), my Employers, my Customers and on my own Fleet and other vehicles. Not once were they ever used to discriminate one lubricant from another on the grounds of wear metal uptake!
By Doug Hillary
