ok, so i am in the middle of a project that was supposed to be small, and about oil filters and stuff, but soon became quite big. I am still kind of a novice when looking at these additive packages and all that, so i need a bit of help from you guys. Below is an element analysis of the following oils:
Amsoil 100% synthetic 5W-30
Biltema synthetic 5W-40
Castrol Edge 0W-40
So, i guess all of you know the Amsoil stuff. I bought it for my car to do a few filtration tests and stuff, and boy was it hard to come by over here in Norway (had to import from the UK)! anyways, it seems quite good so far. the Amsoil in the test is unused.
Next is a little something called Biltema. it is from a quite large company operating over here in scandinavia, and they specialise in "cheap" and sometimes [censored] auto and home improvement products. The Biltema oil in the test is about 1/5 the price of the Castrol. Biltema oil is unused for the test.
Last but not least is the Castrol Edge 0W-40 oil. It is amongst the most expensive oils one can get in the shops over here. This particular sample is USED. it has been in my engine for about 4500 kms and has been worked moderately. i guess moderately is kinda a relative expression here since the car is a Honda Integra Type R, and the oil has recieved quite a bit of beating. anyway, i will post up results on a unused sample as soon as i get one.
and here are the results ( i hope you get everything considering the written language):
Take a look at these results, and tell me what you think. especially i want you guys to take a look at the Biltema vs the Amsoil. there are certain things there i am a bit sceptical about... i will comment on those things later, when you have looked a bit, so that my opinions will not influence
by the way, i have also got particle counts for these samples, but i can reveal these later
thanks for all your help
Castrol Edge 0W-40
