I have been concerned for some time about the tight fit of the element endcaps to the can on the ecore style (most new Super Techs, AC/Delcos, STPs, etc.) and how that might affect oil flow and pressure.
Today I put an STP S2870A of this design on my '69 VW van to test it, and the oil pressure is great. Maybe a little better than the K&N I had on there just before.
(The OP gauge is tapped after the filter.)
Now granted, this 47 HP, 4 cylinder air-cooled engine with 21mm oil pump gears probably doesn't pump the volume of a bigger engine--especially relative to the medium/large filter size it uses.
But still, this filter seems to flow just great in this application.
Apparently the fabric type endcaps edges do give way and allow a fair amout of oil into and through the filter. Perhaps my concerns about the Ecore design is unfounded.
