Originally Posted By: peterdaniel
I have a 2006 Jetta TDi. It has no fancy schmancy clean exhaust system. Its extremely quiet.
Wow. C'mon Peter, read my postings and give them a little thought. I'm not attacking diesel. It's a good technology, that simply has a different set of strengths and weaknesses as compared to the gas-electric hybrids.
As for the exhaust system, you're one of the last lucky ones. The new cars do have more complex and expensive systems. Let's face it, as good as diesels are in many ways, the untreated exhaust can be pretty nasty, compared to a modern gas engine that's in good health. My point was ONLY that the new models DO have systems that are likely (certainly in the case of MB) to cost every bit as much to replace as a hybrid battery. No free lunches for either side here. Now, I will readily acknowledge that a key distinction is that the new clean diesel exhausts are more a function of government mandate, whereas the hybrid battery is an inherent part of the system. But hey, even if you can cut away the exhaust, you still get back to the basic distinction -- hybrids really shine in more urban driving; diesels on the open road.
I run Mobil 1 TDT in it which is a 5w-40
OK, I'm missing how this connects to this debate. Seriously (not snottily), am I missing something?
I get 40 mpg all day long stop and go, highway combo figure 65/35 split respectively.
I have no cap, no rotor, no spark plugs and no emission testing I have to do.
Peter, I'm amazed that I have to keep saying this. Your Jetta is a
much smaller car than my Camry. Heck, it's much smaller than the Prius my son is now driving. The Camry has almost 102 cubic feet of passenger volume. The Prius has 96.
And your Jetta has ONLY 91! And the Jetta is also more than
a quarter ton lighter than my TCH. I would seriously hope that a car that small does this well, especially being a diesel. BTW, the EPA (old, overly generous system) for the 2006 TDI Jetta is 30/38 (or 30/37 for the manual). Hmmmm...
EDIT: Oh, I forgot to add. I don't have a cap or rotors either. Nor do I have emissions testing where I live. I do have spark plugs, but only four of them, and Prius or Camry, the whole set can be swapped out in maybe as much as ten minutes. As the plugs are plainly good for ~100k miles, I might have to spend 45 min over the total life of either car doing plugs. Hardly a major burden. . .
I can run 100% Biodiesel. Heck, I can run Waste vegetable oil if I really wanted to with simply modifications. My emissions at that point would be about nill... and not using anything that wasn't renewable..
Well, to put it a tad bluntly, I don't care. As I repeat all the time, while I do care about the environment, I did not buy either of our hybrids for that purpose. I do commend you, and anyone else who tries, for your efforts to keep your car's emissions to a minimum. FWIW, a year or so ago, I found myself behind an ancient Rabbit diesel, with biodiesel and progressive fuel stickers all over it. Don't know what was in its tank at that moment, but the car gave off the overwhelming smell of a donut shop. Sorta cool I have to admit.
I have all the bells and whistles, plus 10 airbags Dynamic stability control, ABS, A/C. heated seats, moonroof, 6cd awesome sound system and a trunk with a fold down rear seat that will swallow just about anything you can think of. I have full auto up AND down power windows.
OK, I've got all of those, except for the moonroof (which I don't want as I have a long body, and my head always rubs on them), heated seats (yeah, even in FL, I'd take those), and heaven forbid, my auto windows are only auto on the way down. Oh well... OTOH, if I get sleepy, I can pull into a rest area, on a sunny summer day, in my JET BLACK Camry, and nap for twenty minutes with the AC blowing nice cold air, running completely off the traction battery, and burning not a drop of WHATEVER is in the fuel tank. As good a car as your Jetta is (and repeating, I DON'T dispute that), it will NEVER perform that feat for you. You don't realize just how cool (literally) this capability is, until you've enjoyed it for yourself.
I can run down to Orange county in 100+ degree of heat with the A/C on full blast and go about an average of 85-90 mph.
Even the Prius does that just fine. . . Point?
And I still get 43 miles to the gallon.
Well, funny that you mentioned that particular figure. Look what I found this morning. The figure you see is significant it that it reflects how the TCH behaves in PURE urban driving, with no highway at all. This is over almost 50 miles of driving since the last fillup. No tricky hypermiling, no neutral coasting (bad in an HSD car anyway), just sound moderate driving making reasonable and safe use of the terrain, and not interfering with other traffic.
NEVER have I EVER had a problem finding fuel. Much like your battery hype, that is simply a false statement.
Be careful and read and think before you accuse people of making "false statements". My observation was simply that, at least where I live and drive, it seems that only about one in four gas stations actually offers diesel fuel. That's decidedly NOT false, it's, ummmmmm,
TRUE. We can quibble about what a "problem" is, but my point is simply that I can drive into ANY filling station without thinking about it. You can't. If you're OK with that, well that's wonderful.
I run my oil for 5K and then change it out. My filter sits on top of the engine, extremely easy to get to.
And. . .
I have 1/2 the electrical wiring/gizmos to go bad than any other car.
Yep, we've had Toyota hybrids here for almost a decade now, and they're falling out right and left because of all those unreliable systems. . .
My resale value is extremely high.
As is mine...
I can easily expect 250K miles out of this engine.
And I should not see the same?
I have way fewer things to go wrong that will leave me stranded.
It's a VW. I've owned ONE of those myself. I was not impressed at all with the frequency with which "things" went wrong. I hope you have a good one. . .
and lastly, Unless you buy used you are not helping the environment by buying a NEW hybrid. You are simply adding to the mass consumption of raw materials.
Well, I guess you have not been reading my posts, because if you had, you'd see that
I bought both our Prius and the Camry USED!!! BTW, ANY car bought new, represents a rather large chunk of natural resources carved brutally from Mother Earth. Your Jetta is not an exception.
Imagine a smaller diesel in a car that weighs the same as the civic... or perhaps a Toyota Yaris... Ford has one and so does VW.
They get 65 mpg.
I can easily imagine such a thing -- but I don't want to. I don't want a little Jetta or Civic or Yaris. I want extreme mileage, AND a relatively BIG car. Please get back to me when you find another product, irrespective of the drive technology, that offers well over 100 cubic feet of interior while getting Yaris/Civic fuel economy.
