The results below are from my 1987 (20 years! Where does the time go?) Yamaha FZ700. I am the original owner and the bike has just shy of 111,000 miles. The bike is used year-round, typically 5 days a week commuting to work and a few trips to the twisties throughout the year.
Here it is:
Ill post last years results as well
Oil: Amsoil AMF 10W40
Miles on oil: 7215 (2007) / 5900 (2006)
Time on oil: 1 year / 1 year
...............2007....2006
Iron............18......17
Chromium.......0.......1
Lead.............2.......2
Copper.........8.......8
Tin..............0.......0
Aluminum......12......11
Nickel...........0.......0
Silver...........0.......0
Silicon..........7.......7
Boron..........14......29
Sodium..........0.......0
Magnesium.....61.....170
Calcium.....3693....3586
Barium............0.......0
Phosphorus..1240....1304
Zinc..........1588....1690
Molybdenum.......0.......0
Ti/Van/Pot.......0.......0
Fuel:.......... Vis @ 100c:..11.46...11.65
H2O/Soot/Coolant: None (both years)
TBN :.........6.56....7.18
Oxides:.......14.0....12.0
Nitrides......15.0....15.0
I made the mistake last year of changing the oil after taking the sample. As you can see, I wasted 4 qts of good oil. This year I left the oil in. I added 1/2 qt make-up oil. I intend to run this oil as long as the UOA says it still has life.
I have a spare engine for this bike so I am going to see just how long this will last, at which time I will swap engines.
I am very happy with these reports, and considering how the Amsoil has clearly affected my fuel mileage and feel of the clutch, very happy with the oil in general. The Viscosity has slipped some, but it hasnt moved enough to be meaningful, and this may not be the oils problem as I may have a thermostat issue, the bike has been running hotter than usual.
Here it is:
