Originally Posted By: Donald
so when the pads wear oddly, the ones I am replacing, the inner pad had plenty of pad left (over 1/4"), the outer pad was gone, not even the metal mounting plate was there, and the caliper was leaking, I just replaced the caliper and am hoping it was not also the sliding pin(s).
I believe that typical, Average-Joe floating calipers will wear the inside pad first when things start to seize up. Pulling the outer pad "in" requires more things to slide and move which can get gooped up. Wearing the outer first might mean your old inner *pad* was simply jammed or incorrectly installed (?) and there was nothing wrong with your caliper.
