Usually it's a sign of one or more of the following:
(1) excessive gasoline remains inside the combustion chamber even after shutoff, causing "auto-ignition" (similar to dieseling due to compression ignition) even after you turn off your engine.
(2) carb is out of adjustment somewhat.
(3) air filter is a bit clogged, causing the carb to run a bit rich.
or a combination of 1 or more of the above.
Usually, if it's the older, pre-cat days cars with carb usually tends to over-run a bit even after shutoff and this is fairly normal and there's nothing I would do to it (doesn't bother me at all).
Q.
