Brakes for 2012 Subaru Legacy
by Picky1
2 minutes 20 seconds ago
Microgreen Oil Filter 50% Off Discount Code
by kohnen
7 minutes 53 seconds ago
Don't believe the hype of "never change the oil"
by Fsharp
28 minutes 5 seconds ago
tzlk to me about aeroflot
by Jetronic
Today at 12:21 PM
My extended drain OCI did not go as intended...
by firemachine69
Today at 11:10 AM
Honesty
by stockrex
Today at 11:04 AM
Valvoline's New "Cobalt" Grease availability
by EdandSherry
Today at 10:47 AM
Mobil Delvac 1 5w40: where to buy?
by car51
Today at 10:38 AM
Honda EM7000is stored too long with fuel
by henni
Today at 10:04 AM
1967 Ford F250- cooling system flush w/ Cascade??
by ryanschillinger
Today at 10:02 AM
Oil for FTO MIVEC used on track
by Spetz
Today at 09:13 AM
[Cut Open] Motorcraft FL500S - 5316mi
by DuckRyder
Today at 09:04 AM
Jennyp, dcdodge, igolfat8, makomike, Alexas
58338 Registered Users
90 registered (arob85, 13Tacoma, 1foxracing, aquariuscsm, 09_GXP, 13 invisible), 2037 Guests and 11 Spiders online.
58338 Members
66 Forums
251102 Topics
Page 1 of 3 1 2 3 >
#1505760 - 06/20/09 08:52 PM No more Fram Air Filters, STP only! (56k beware)
ToyotaNSaturn Offline
Loc: Spring Hill, TN
Purchased a new Fram filter for the 04 Vue V6 today. So I went to install it tonight when I changed the oil (PP 5w-20 for those with inquiring minds). First thing I noticed was that it looked different and that it was a bit lighter in weight.
The box was in perfect shape, yet the outboard pleats are crunched. The rubber perimeter comes off easily.
Two Side-by-Side pix:
The old filter, an STP filter with about 14K on it, has 24 pleats. They are rather sturdy and unflimsy.
Conversely, the Fram has only 18 pleats that are easily flexible. Cheap is a better word to describe this $12.47 + tax filter at WalMart:
It doesn't matter what foreign country these are made in IMO, the STP filter is a better product. I won't be purchasing Fram air filters any longer. STP has my business from now on.
2006 Mercury Montego, V6
2004 Saturn Vue, V6
#1505777 - 06/20/09 09:01 PM Re: No more Fram Air Filters, STP only! (56k beware) [Re: ToyotaNSaturn]
Mr Nice Offline
Loc: Orlando, FL
Maybe a customer looked at the filter and shoved it back in the box and it got damaged ?
2007 Civic EX
2006 Accord SE
2005 RSX base
#1505799 - 06/20/09 09:23 PM Re: No more Fram Air Filters, STP only! (56k bewar [Re: Mr Nice]
Yuk Offline
Loc: Edmonton, AB Canada
Maybe, but the STP filter looks rigid enough to have not been damaged if some ham fisted person tried to shove it back in the box. Regardless of what caused the damage, I'd say this is still a black mark against Fram.
#1505800 - 06/20/09 09:23 PM Re: No more Fram Air Filters, STP only! (56k beware) [Re: Mr Nice]
I just went out to the garage and found *another* exact one of these. I forgot I bought one a few months ago. Same issues: bent outboard pleats, flimsy construction, etc.
Khomplete Khrap.
2004 Saturn Vue, V6
#1505803 - 06/20/09 09:27 PM Re: No more Fram Air Filters, STP only! (56k beware) [Re: ToyotaNSaturn]
The Critic Offline
Loc: Walnut Creek, CA
That's strange.
The Fram air filter for my SL2 is better than the Wix one that I recently purchased.
11 Prius - 129k - M1 EP 0w20/OE
07 Accord 2.4 - 111k - M1 5w20/FPS Filter
10 Altima 3.5 - 34k - M1 EP 5w30/FU
92 Previa - 160k - Chevron 5w30/Wix
#1505809 - 06/20/09 09:31 PM Re: No more Fram Air Filters, STP only! (56k beware) [Re: The Critic]
GROUCHO MARX Offline
Loc: The Sandhills of NewYorkistan
I've been using Delcos and Wix.
80% of people polled say that their neighbor should take mass transit to work.
#1505843 - 06/20/09 09:54 PM Re: No more Fram Air Filters, STP only! (56k beware) [Re: The Critic]
MONKEYMAN Offline
Loc: St. Louis
 Originally Posted By: The Critic
That's strange.
The first air filter I put in my SL2 was a Wix/Napa Gold one. The intake sucked a hole about 1" where it lined up sometime before 7,000. Since then I have used Fram with no problems. If I buy a fuzzy filter it will be OEM one. I don't trust the aftermarket fuzzy design.
Truth alone triumphs, not untruth.
#1505846 - 06/20/09 09:58 PM Re: No more Fram Air Filters, STP only! (56k beware) [Re: ToyotaNSaturn]
StevieC Offline
Loc: Niagara Falls, ON, CA (near)
Really, you aren't going to buy Fram anymore because of 2 slightly dented pleats which will have no effect on the filtration? What if someone took it out of the box and bent the pleats prior to you getting it?
I could see if the gasket or media was badly damage or the filter was warped or not fitting in your air-box properly, but then that's 1 filter out of how many they make in a day? C'mon get real!
So if you go to a restaurant and they happen to get your order wrong or the food isn't to your liking are you never going to eat there again?
If you want to buy the STP because it seems better built with the center piece of plastic, that's fine but to call FRAM no-good because of slighty damage pleets and a "lighter" design is just childish
JMO, don't get angry.
Edited by StevieC (06/20/09 10:05 PM)
'06 Hyundai Sante Fe - 330K KM's
Current Oil: RLI 0w30 (Ask me why)
Don't be part of the Sheeple, check frequently for wool over your eyes. wink
#1505858 - 06/20/09 10:16 PM Re: No more Fram Air Filters, STP only! (56k beware) [Re: StevieC]
I'm not angry at all. I'm not being childish neither. When you place a McDonald's cheeseburger next to a home-grilled burger, and they cost the same, which one would you prefer?
Would you continue to frequent a restaurant if you received sub-par overpriced food, twice?
This thing isn't worth $2 let alone $12+... Value is part of the price. There is no value in this Fram item.
My kids can make a better quality air filter with a couple pieces of notebook paper, a plastic coat hanger and a bottle of Elmer's glue.
2004 Saturn Vue, V6
#1505876 - 06/20/09 10:35 PM Re: No more Fram Air Filters, STP only! (56k beware) [Re: ToyotaNSaturn]
moklock Offline
Loc: FL
The Fram he is showing is junk. I looked at one for my '03 VUE a few years back. I also would not use due to the very poorly fitting gasket alone. The Saturn filter element is $25-$30 IIRC but is waaay higher quality.
#1505912 - 06/20/09 11:11 PM Re: No more Fram Air Filters, STP only! (56k beware) [Re: moklock]
StevieC Offline
Buy the better quality one yes, but to start a thread with pictures and complain that you aren't buying FRAM any more because of dented pleats is a bit crazy don't you think?
Slightly dented pleats aren't going to affect the filtration, and the gasket although it could be better I'm sure will seal just fine
Now if you posted "Fram compared to STP" and left it open for discussion fine.
I agree with you for the price I would get the STP... I just didn't like the way you approached the thread, to me it seemed childish.
#1505979 - 06/21/09 12:25 AM Re: No more Fram Air Filters, STP only! (56k beware) [Re: StevieC]
daves87rs Online   content
Loc: Michigan
Interesting difference....
Whatever you are, be a good one.
#1505989 - 06/21/09 12:40 AM Re: No more Fram Air Filters, STP only! (56k beware) [Re: daves87rs]
sunfire Offline
Loc: Ca, US
I actually prefer the Fram over SPT. I had a SPT filter replaced by the Valvoline quick lube (my pre bitog days). With only 1K miles on the SPT switched it out for a Fram from AutoZone made in Israel. I noticed much better low end torque immediately on the trip back home. The Fram is still in my 05 Corolla now.
I actually don't like that piece of plastic down the middle, I think it restricts air flow. The Corolla filter is smaller than yours so every bit counts.
2005 Toyota Corolla LE | 65,000 | PYB 5W-30
#1506030 - 06/21/09 02:22 AM Re: No more Fram Air Filters, STP only! (56k beware) [Re: moklock]
Superbuick96 Offline
Loc: Cleveland, OH
A few years back I went to Murray's for a new Motorcraft air filte. So the counter guy said it was 18.00,and I said gimme the Fram for 12.00. Then he took the 2 filters out of the box and had me check them out. Needless to say I spend the extra 5.00 for the MC. There was no comparison in quality.
03 Chevy Blazer 4.3 4x4 Vavoline Maxx Life FSyn 5w30
04 Ford Ranger 4.0 4x4 M1 5w30
07 Saturn Vue 3.5 AWD M1 5w20
#1506142 - 06/21/09 08:46 AM Re: No more Fram Air Filters, STP only! (56k beware) [Re: StevieC]
That's not the angle I was coming from. Cheap quality Fram products is what I was trying to display here, bent pleats being only one part of the experience. If I didn't portray the larger meaning, then it's my fault for not explaining things thoroughly.
As for the Fram vs MC filters...
Same story. When I worked in Ford parts, I was amazed at how the no-name brands were flimsy & cheap compared the Motorcraft-labeled products. Several mechanics swore by them as they wouldn't sag when the filter became damp. However, the MC products did cost more then that knock-offs...
2004 Saturn Vue, V6
Page 1 of 3 1 2 3 >
