5VZ-FE engine has ~ 150k miles & needs the timing belt replaced. What is recommended to be replaced outside the OEM timing belt? Oil pump & cam seals? I assume the 3 accessory belts. Coolant change. Water pump? $140 from OEM. Thermostat? New crankshaft pulley bolt as the link below says is in the FSM?
Harmonic Damper Pulley Holding Tool seems like a good tool to have here. Thoughts?
Is there still an online location to down the FSM for ~ $10?
Is Technical Information System where I want to go for that? If so, can just anyone subscribe? Does it have downloadable factory service manuals?
Toyota Parts & Service lists:
Repair Manual VOL 1 RM1090U1 $103.90
Repair Manual VOL 2 RM1090U2 $133.58
Are the instructions in this link spot on? If not, what is different?
Toyota Maintenance: TB Replacement
I feel better about tackling this for the 1st time in a non-interference engine but all help is certainly appreciated.
Thanks.
Thanks.
