Hello guys! I'm not very used to that transmission and since I have the car, I always questionned the transmission. On my 05 cts 3.6l, there's a 5l40e transmission drive-by-wire.
My question is this: Is this normal that when hitting full throttle, there is a delay between the 1st and 2nd gear? I dont think the transmission is slipping because it would cause the engine to over rev a bit but thats not the case. Between the 1st and second gear shift, you can see the rpm drop and there is like what it seems a second delay before the transmission kicks in (feels like a manual transmission).
That was my first question and the second one now:
Again with the transmission... When hot outside and when ONLY the a/c is working, coasting downhill between 70-90 km/h, the tcc seems to unlock and lock (only once). (the rpm goes to 1900 rpm to 1000 rpm and just go back to 1900 rpm). At 70 km/h, the engine and transmission when coasting down a small hill try to maintain the speed I guess but you can see the rpm drop from 1500 to 900 and then go back to 1500, drop back to 900 and so on (only when at that speed). It stops if I go lower than 70 km/h or higher than 80 km/h. All that without the foot on the accelerator. During winter time, I dont use the A/c so the transmissio doesn't act like that.
Thanks a lot and hope to find some answers here!
P.S: its still a clue for the caddy forums.
